1997 Ford Explorer Power window regulator
WILLSR
Interior problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic
How do you change the power window motor
Jan 23, 2010 at 10:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1.Raise the window fully if possible. If not, you will have to support the window during this procedure. Disconnect the battery ground.
2.Remove the door trim panel.
3.Disconnect the window motor wiring harness.
4.There may be a drill dimple in the door panel, opposite the concealed motor retaining bolt. Drill out the dimple to gain access to the bolt. Be careful to avoid damage to the wires.
5.Remove the motor mounting bolts (front door) or rivets(rear door).
6.Push the motor towards the outside of the door to disengage it from the gears. You'll have to support the window glass once the motor is disengaged.
7.Remove the motor from the door.
8.Installation is the reverse of removal. To avoid rusting in the drilled areas, prime and paint the exposed metal, or, cover the holes with waterproof body tape. Make sure that the motor works properly before installing the trim panel.
Jan 23, 2010 at 10:52 AM
