1997 Ford Explorer fuel injection/ fuel pump
JAYKAY68
  • 1997 FORD EXPLORER
  • V8
  • 170,000 MILES
HI! I had my fuel pump replaced around 140K. No big deal. Everything was fine for the last 2 yrs. Then, the other day, I parked on a hill, facing forward, and the car wouldnt start. We got it on level ground, and it started, but NOW, every time I start the car, its slowwww to start and seems to be 'gasping' for gas. Its a V8 so its never been 'shy' when I hit the gas pedal. Any suggestions?
Thursday, December 10th, 2009 AT 7:11 PM
  • 109,885 POSTS
Because of the way you were parked, the fuel was low enough that the pump couldn't pick it up. As far as the harder starting, try replacing the fuel filter. You may have picked up dirt from the empty tank.
See if that helps.
Thursday, December 10th, 2009 AT 9:10 PM
RICKMAR
  • 170 POSTS
Hi JayKay;
I have had the same thing with a 1999 Mountaineer "facing forward with low fuel".
What you are describing with the slooww starting and gasping for fuel is very odd. It could be the fuel filter but I doubt it.
Hopefully this will take care of it for you, it will cost about $10.00 but it is worth it.
The solution is called "SeaFoam" you can find it in any automotive store.
https://www.2carpros.com/forum/automotive_pictures/433905_SeaFoam_copy_1.jpg
While your engine is running SeaFoam will enter your combustion chamber to do a thorough cleaning. It will put up a pretty good smoke show like this:
https://www.2carpros.com/forum/automotive_pictures/433905_seafoam_exhaust_1.jpg
You might want to find a low populated place to let it burn off.
*SeaFoam burn off Smoke picture credit to JLSparky7's (Serious Explorations).
There are a few different procedures of how SeaFoam is used.
The link below is for a video to get the best results using SeaFoam. Performed on a 1996 explorer 5.0L "all years" are compatible.***Tip>>> You do not have to put SeaFoam in your oil if you do not want to, I don't...I use (1/2 vacuum line intake) (1/2 fuel) <<<***
Here is the link *(credit to JLSparky7's)* :
Length (3 min. 19 seconds).
http://www.youtube.com/watch?v=SRfVcvcMycc
I hope that works for you.
Good Luck;
Rick
Thursday, December 10th, 2009 AT 9:45 PM
