1997 Ford Explorer Door Latch Won't Open
BUTTERFLIDRM
I have a 1997 Ford Explorer AWD V8 with 157718 miles. The rear interior door handles will not open the doors. I have replaced the handle itself, which was broken. Now, the latch still will not release leaving the door unable to open from the inside. I have checked to be sure the child-safety lock is not engaged. Also, the rod does not seem to be bent. What else could be causing this issue?
Sep 25, 2007 at 5:09 PM
MERLIN2021
  • 17,250 POSTS
Try getting some brakekleen and spray white grease, spray liberaly the catch 4-5 times opening and closing from the outside. Then aply a liberal coat of grease. It has to be an issue of binding someplace in the mechanism!
Sep 25, 2007 at 7:42 PM
Suggested Repair
Spray brake cleaner and white grease liberally on the latch catch several times while opening and closing the door from the outside, then apply a liberal coat of grease to free binding in the mechanism.
Conversation Summary
The owner of a 1997 Ford Explorer says the rear interior door handles will not open the doors. The handle was replaced, the child-safety lock is not engaged, and the rod does not appear bent, but the latch still will not release from inside. The expert recommends cleaning the catch with brake cleaner and white grease while cycling the door from outside, then greasing it, because the mechanism is likely binding.
