Are you sure its the heater core hoses not the upper and lower radiator hose?
Sunday, September 27th, 2020 AT 11:51 AM
(Merged)
SONIALINN
MEMBER
1 POST
1996 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
172,000 MILES
The heater in my Explorer works intermittently. It blows out cold air and the temperature gauge rises to the red, indicating that it's trying to overheat. Also the temperature gauge needle fluctuates dramatically, like a bobber in water. The thermostat has just been replaced and antifreeze was added. It is still doing the same thing. This is about the third thermostat that has been installed in the past three years. This time it is not doing the trick.
(Merged)
MECHANIC
Try removing the thermostat and see what happens to the temperature-
Also did you bleed out the cooling system?
Above don't work do a block and pressure tests to confirm there's no combustion gas leakage.
(Merged)
HIGHTOWERTAN
MEMBER
1 POST
1996 FORD EXPLORER
Heater problem
1996 Ford Explorer 4 cyl All Wheel Drive Automatic
What could be the problem as to why my heat isn't working. I had my thermostat fixed but there still isn't not heat.
Sunday, September 27th, 2020 AT 11:52 AM
(Merged)
MECHANIC
I need you to check something. With the engine running, hot, and the heater on, feel both heater core hoses to see if they are both hot.
