1996 Ford Explorer leaking undernealth car
178,788 MILES • 6 CYL • 4WD • AUTOMATIC
FORDEXPLORER2010
I have a 1996 ford explorer withn 178,788 miles.There is a oil leak undernealth the the truck.The oil light has not come on and no indication that the oil is low.What could be the problem and if I continue to drive the truck will this cause extensive demage.
Oct 19, 2010 at 3:51 AM
  • 110,248 POSTS
It could be from a few things, the oil pan, valve covers... Keep an eye on the oil level and make sure it stays in the safe range. That will protect the engine. However, if there is a bad leak and enough gets on a hot engine, it could cause a fire.
Oct 19, 2010 at 6:20 AM
