1996 Ford Explorer ABS light on
177,863 MILES • V8 • 2WD • AUTOMATIC
DABEARMAN54
Where can I locate the ABS sensors to try to cleam them out to see if light in dash goes off?
Jun 6, 2009 at 5:07 AM
JGAROFALO
  • 489 POSTS
[quote:465086f065="dabearman54"]Brakes problem
1996 Ford Explorer V8 Two Wheel Drive Automatic 177863 miles
Where can I locate the ABS sensors to try to cleam them out to see if light in dash goes off?[/quote:465086f065]
The ABS sensors are located on the back side of each front spindle and there is one on the top of the differential housing.
I sincerely doubt if cleaning them will solve your problem. I suggest that a bit of diagnosis is in order. The system does store trouble codes, but you need an older type of scanner for Ford products to read the code(s).
Jun 7, 2009 at 1:13 AM
