1995 Ford Explorer After fuel pump replacement, gas gauge s
195,000 MILES • 6 CYL • 4WD • AUTOMATIC
MLENTINI
Hello, I just replaced the fuel pump (entire assembly) and now my gas gauge is stuck past full. I would like to prevent pulling the tank again so I'm hoping there are some things I can check before that. The new assembly I put in is a direct Ford replacement (sending unit, pump, float, etc.). Thank you in advance for your answers!!
Sep 30, 2010 at 5:29 AM
  • 110,248 POSTS
It sounds like the float was jammed in the upright position or when you replaced the wiring, something jammed or shorted. I hate to say it, but I feel the tank needs to come back out.
Oct 1, 2010 at 6:25 AM
MLENTINI
Thank you. I found some simple things online that I'll check first with the wiring to see if it's shorted, but I guess if it's gotta come off I'll suck it up. Thanks again.
Oct 1, 2010 at 7:33 AM
