1995 Ford Explorer
ROCK7766
  • 1995 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 130,000 MILES
When I drive my explorer I always have vibration that at certain speeds gets worse or better. When the gas peddle is backed off on at say 50 it gets bad u feel the shaking thew out the suv. It feels like the drive axle I just replaced the upper ball joints on both sides. I was told theres a bearing or seal of some sort on the part that slides into the tranny. Do u have any clue to if theres something that needs to be replaced inside the tranny and does it require to take the tranny out or can it be done as is
Friday, November 7th, 2008 AT 7:26 AM
DAVE H
  • 13,383 POSTS
Thought this might help?
TEST B: VIBRATION AT HIGHWAY SPEEDS
Possible Sources
Out of balance front wheels or tires.
Out of round front tires.
Improperly seated outboard front wheel axle shaft joint (fixed type) in front wheel hub.
Actions To Take
Inspect and replace tires if necessary.
Replace axle shaft and joint assembly.
Friday, November 7th, 2008 AT 8:35 PM
