This sounds like a cracked cylinder head or head gasket - but there are other possibilities.
Check for coolant in the oil. Check for transmission oil in the vacuum line that runs down to the transmission. Check coolant and transmission oil levels.
White smoke is caused by a "non-fuel" substance being burned in the engine. There are several possible sources.
Coolant can enter the combustion area from a bad intake manifold gasket, a cracked head, or a head gasket. This will produce white smoke.
Transmission oil can enter the engine through the vacuum modulator line to the transmission. This will also produce smoke - though usually more likel burning oil.
Brake fluid coming from the master cylinder through the brake booster will also produce white smoke.
You must first determine the source of the smoke to make repairs.
SPONSORED LINKS
Monday, March 30th, 2009 AT 5:22 AM
