1993 Ford Explorer Wont start after shutdown
BRNIN49
  • 1993 FORD EXPLORER
  • 6 CYL
  • 130,000 MILES
To restart the fuel shutoff button has to be reset, does this just mean the reset bytton has to be replaced or are there sensors in other places that could be the culprit. It happened first a week ago and now happens intermittently after shutdown?
Monday, December 24th, 2007 AT 6:13 AM
MERLIN2021
  • 17,250 POSTS
Do you smell gas? This switch is designed to shut fuel off after a crash, when leaks could be a concern. If no fuel leaks, replace the switch.
Monday, December 24th, 2007 AT 7:16 AM
BRNIN49
[quote="merlin2021"]Do you smell gas? This switch is designed to shut fuel off after a crash, when leaks could be a concern. If no fuel leaks, replace the switch.[/No gas smell so I guess its the switch. JDB
Monday, December 24th, 2007 AT 8:40 PM
MERLIN2021
  • 17,250 POSTS
One question first, is the button down? If so test it for resistance, if no resistance it's good. But if it keeps popping change it out.
Tuesday, December 25th, 2007 AT 7:51 AM
