1993 Ford Explorer wont start
REOSPEEDWAGON
  • 1993 FORD EXPLORER
Electrical problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic 96.000 miles
car just clicks battery starter. Cylinoid. Relay switch all good cables and ignition switch also good any ideas would be helpful
Monday, September 6th, 2010 AT 12:30 PM
Is it cranking over and will not start or just won't crank over at all/nothing when key at start position?
Monday, September 6th, 2010 AT 5:09 PM
REOSPEEDWAGON
Car will crank over when jumper cables are hooked up directly to the starter and ignition switch is turned on all the way
Monday, September 6th, 2010 AT 9:53 PM
W/O cables try to engaged the starter by shorting out the starter relay and see what happens
Monday, September 6th, 2010 AT 10:06 PM
