1993 Ford Explorer running bad at times
93EXPLORER
  • 1993 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 90,000 MILES
I have a 93 explorer, at times you will be going down the road smoothly at speed limit. Then all of a sudden big power loss and almost stalling. And most times it wont do that. And it will have a stong smell to it. When I stop. All gauges read normal, heat, press, bat.
Friday, March 12th, 2010 AT 6:57 AM
  • 109,709 POSTS
I would start by checking two things. First, it sounds like the catylatic converter may be plugging and causing a power loss and the smell. If it is good, you need to check the fuel pump pressure to see if it is low.
Let me know what you find or if you have questions.
Saturday, March 13th, 2010 AT 12:23 PM
