2000 Ford Explorer engine runs rough
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
JBASSNV1
my 2000 ford explorer runs rough ,have tuned it up
replaced plugs ,wires fuel filter ,air filter.Are there any sensors that need to be replaced with the engine w/this many miles on it? Or other items to be checked out?
Thanks
Jim
Nov 4, 2008 at 8:15 AM
MASTERTECHTIM
  • 4,750 POSTS
is the check engine light on? if it is then have the computer scanned for codes and get back to us. autozone will scan it for free. the first thing that comes to mind is a intake manifold vacuum leak causing a lean misfire but have it scanned first.
Nov 4, 2008 at 9:39 PM
JBASSNV1
Thank you for your response.
the check engine light has never come on and i have
had auto zone check to see if there are any codes to be pulled also.
Nov 5, 2008 at 12:16 AM
MASTERTECHTIM
  • 4,750 POSTS
i would look for a vacuum leak by spraying carb cleaner at lower intake manifold and see if idle changes.
Nov 5, 2008 at 3:09 AM
