1993 Ford Explorer Need help asap
100,000 MILES • 6 CYL • 4WD • MANUAL
PUGZ1985
I have a 1993 Ford Explorer XLT 5 spd with about 100,000 miles on it. I put a new clutch and cylinder in it in 07. I was driving to work today and came to a stop and when i started to go i let the clutch out and got nothing but rpms. No grab what so ever. I have full clutch pedal and pressure and it goes in and out of gear but the truck won't move even a little. This happened with no warning. It was running fine until today. Any ideas whats wrong with it??? Please help!!!
Feb 23, 2010 at 7:50 AM
  • 110,251 POSTS
Is there any noise associated with the problem?
Feb 23, 2010 at 10:37 PM
PUGZ1985
i heard a little click noise when i put it in first and after that nothing. everything sounds normal. just that when i let out the clutch i dont get anything.
Feb 24, 2010 at 4:29 AM
SCOTTY DEE
  • 592 POSTS
Here's a possibility.
Something has broke or come loose in the shifter linkage. You can get a look inside there without too much hassle. Remove the screws from the shift boot retainer and get a look. A flashlight and a small mirror you can put at an angle will be helpful. Let me know what you find out.
Feb 26, 2010 at 4:14 AM
PUGZ1985
Thankyou for responding. Are you ruling out clutch and transmission? And if it is what you said is it a complicated and expensive fix?
Feb 26, 2010 at 10:57 AM
SCOTTY DEE
  • 592 POSTS
I got your email.
Feb 26, 2010 at 11:24 AM
PUGZ1985
My
email address is mikestevens3@verizon.net I dont remember if i gave it to you. thanks again!!
Feb 27, 2010 at 11:58 AM
