With MAF disconnected it wil never run right. The PCM has to know how much air is entering the engine. The TPS, if you swap the leads on the meter, it will probably read + instead of - on the output. This all sounds likea MAF problem, vacuum leak or low fuel pressure
SPONSORED LINKS
Monday, August 11th, 2008 AT 7:49 AM
