HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1993 Ford Explorer fuel system
ISAACMEREDITH
MEMBER
1993 FORD EXPLORER
Engine Mechanical problem
1993 Ford Explorer 6 cyl Two Wheel Drive Automatic
replaced fuel pump still would not work releaved fuel pressure through inertia switch worked for a while 30 mins then stalled and wont start
Thursday, September 30th, 2010 AT 5:05 PM
MECHANIC
Check and monitor the fuel pressure with a fuel pressure gauge and find out what's going on with it. Could be pressure or voltage problem.
SPONSORED LINKS
Thursday, September 30th, 2010 AT 5:22 PM
ISAACMEREDITH
MEMBER
Their is no place to check fuel pressure or to releave fuel pressure
Thursday, September 30th, 2010 AT 5:34 PM
MECHANIC
Thursday, September 30th, 2010 AT 6:36 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
Fuel Pump Replacement Problem
I Am Changing The Fuel Pump On A 1993 Ford Explorer. 4.0l With 4wd. The Old Pump Was Pretty Rusty And The Posts Were Cracked And Broke Off...
Asked by
Scorpgirl75
1993
FORD EXPLORER
GUIDE
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
1993 Ford Explorer Fuel Pump
Engine Mechanical Problem 1993 Ford Explorer 6 Cyl Two Wheel Drive Automatic How To Change A Fuel Pump On A 1993 Ford Explorer?The...
Asked by
emachines
1 ANSWER
1993
FORD EXPLORER
Can Changing A Fuel Pump Take Out The Instrument...
Can Changing A Fuel Pump Take Out The Instrument Cluster
Asked by
ksl
1997
FORD EXPLORER
1996 Ford Explorer How Can I Change The Feul Pump
Engine Mechanical Problem 1996 Ford Explorer 6 Cyl Four Wheel Drive Automatic My Ford Explorer Won.T Start, The Fuel Pump Is Defect...
Asked by
thewanderer00
1996
FORD EXPLORER
Replaceing A Fuel Pump
How Do I Replace A Fuel Pump. What Steps Do I Need To Take And Safely?Is There Anything I Need To Know?
Asked by
David Wood
1996
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Fuel Pump Pressure Test
How to fix an engine that wont start
Engine Not Starting
Online car repair manuals
