1992 Ford Explorer gas going into oil pan
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
WILLIAMKEITH
changed oil and spark plugs still nothing,did run for a few seconds then gas goes back in oil pan.
Aug 3, 2010 at 7:58 AM
  • 110,248 POSTS
How much gas gets into the oil? Does the engine run?
Aug 3, 2010 at 4:12 PM
WILLIAMKEITH
when turning the motor over the only then the gas goes into the oil. pretty much after cranking the first time the second time it run for a few seconds.
Aug 4, 2010 at 5:30 AM
  • 110,248 POSTS
You need to check fuel pump pressure to see if it is too high. If it is good, start looking at the intake gasket. Here is a how to for checking fuel pressure.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find, and most parts stores will lend you the gauge you need. Something tells me the pressure regulator is bad. It has a vacuum line on it. Remove the vacuum hose. If it has gas in it, replace the regulator.
Aug 4, 2010 at 12:48 PM
