1992 Explorer vibration
SEANWV
1992 Ford Explorer XLT, 4.0 V6 Engine, 4 wheel drive, 125,000 miles.
Vehicle vibrates between 55 and 60 MPH when the gas pedal is pressed. The vibration stops when the pedal is released, or the speed is increased to 65 MPH.
Repairs done so far:
Tires rotated
Rear bearings replaced
U-Joints replaced
Front end aligned
Drums and rotors replaced on all four wheels
Any help will be appreciated.
Jan 17, 2007 at 5:01 AM
HEAVYDUTY
  • 60 POSTS
plugs and wires for a possible misfire
Jan 17, 2007 at 1:17 PM
CARUNDELL
  • 602 POSTS
[quote:7982c990dd="SeanWV"]1992 Ford Explorer XLT, 4.0 V6 Engine, 4 wheel drive, 125,000 miles.
Tires rotated
U-Joints replaced
Front end aligned
Any help will be appreciated.[/quote:7982c990dd]
Hey sean
2 items I did not see .....tire balance checked? and which u joints were changed? Let us know!
Chris
Jan 17, 2007 at 10:25 PM
SEANWV
Plugs and wires were replaced 2,000 miles ago on the regular tune-up. The vibration comes from the rear of the car, not the front.
The tires are brand new, replaced 8,000 miles ago, when I bought the car. I did rotate the tires when the vibration started, no change.
And both rear drive shaft U-joints were replaced.
Jan 18, 2007 at 7:11 AM
SEANWV
Just an update for anyone with a similar problem:
I rebuilt the rear, and the problem seems to be fixed. I've driven it 75 miles over the past two days, and there is no sign of any vibration yet.
Jan 24, 2007 at 3:26 PM
CARUNDELL
  • 602 POSTS
[quote:cc7c3c6e34="SeanWV"]Just an update for anyone with a similar problem:
I rebuilt the rear, and the problem seems to be fixed. I've driven it 75 miles over the past two days, and there is no sign of any vibration yet.[/quote:cc7c3c6e34]
Awesome!
Chris
Jan 24, 2007 at 6:55 PM
