If I am not mistaken that vehicle only has front ABS.
First off I would take the wheels off and check the sensor condition sometimes some rust can interfer with the signal cause all the sensor is is a magnet so metal will attract to it.
Then, you can either have the codes pulled to find out which one it is or just replace them both.
SPONSORED LINKS
Wednesday, May 14th, 2008 AT 2:37 PM
