1998 Ford Expedition Brake Pedal to Floor
KIRESHA
I have a 98 Ford Expedition with about 74,000 miles.
Yesterday the brake light with the circle exclamation point under it came on. I jsut got this truck in June of this year and it was serviced before I purchased it.
This morning I could not really stop. I have to push the brake all the way to the floor and then it doesn't stop it slows down adn finally stops when the car has slowed down enough to just stop. I don't hear any rubbing or squeaking like the brake pad are bad.
Is this a problem with brake pads or a problem with the brakes themselves. :(
Nov 21, 2006 at 10:45 PM
BRUCE HUNT
  • 3,754 POSTS
Check the brake fluid in the resevoir. I suspect it is low and thus indicates a leak. See if there is any fluid around the master cyliinder both in the engine well on the firewall and on the inside of the car. Could be you master cylinder that is failing.
Nov 21, 2006 at 11:30 PM
Suggested Repair
Check the brake fluid level in the reservoir. If it is low, inspect for leaks around the master cylinder on the firewall in the engine bay and inside the vehicle. A failing master cylinder is a likely cause.
Conversation Summary
The owner of a 1998 Ford Expedition said the brake warning light came on, then the pedal went to the floor and stopping power became very weak, with no pad noise. The expert advised checking the fluid level for a leak and inspecting the master cylinder area inside and outside the firewall, noting that the master cylinder may be failing.
