2003 Ford Expedition O /D light blinking, slight slippage.
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALLTROJAN24
My quetion is this, I have over 200000 miles on my truck, and I believe we only change the transmission fluid once. Would it be wise to have it flushed. After talking to a one auto mechanic he recommended that I don't, but to buy some Lucas tranmission cleaner, and hope the best?
Not sure what to do? I don't have alot of money to spend.
Aug 3, 2010 at 6:06 AM
  • 110,248 POSTS
Is the present fluid burnt and really dirty? If it is, don't change it. If you already have a slight slip, it will get worse. What happens is this. The old fluid contains dirt, clutch material... When you change it with new, there is a detergent in the fluid that cleans things. As a result, the trans starts slipping more. If you got 200K out of the trans, it may just be time for an overhaul if it is slipping.
Aug 4, 2010 at 10:50 AM
