2001 Ford Expedition No start, stall
SERDONTOS
  • 2001 FORD EXPEDITION
  • V8
  • 4WD
  • 95,000 MILES
2001 Expedition had intermittent crank but no start then start right away condition. Now it won't start unless pressing accelerator, but stalls after letting off pedal, can sometimes get it to weakly idle at 400 - 500 rpm. Fuel pressure checked and good, no vacuum leaks found, no fault codes present, gauges sometimes "peg" when turning ignition key, any help would be appreciated
Wednesday, December 5th, 2007 AT 6:43 PM
BLACKOP555
  • 10,371 POSTS
Take off the air intake hoses and clean out the throttle body and take off the IAC, the pintle should move around freely also there should be no scoring in the housing or on the IAC itself. If not replace it.
Thursday, December 6th, 2007 AT 7:21 AM
