Without seeing the vehicle, it is rather difficult to diagnose a noise problem. We can only depend on the customer's description. Your next free morning, open the hood, have an assistant start the vehicle, and you check under the hood and under the car to find out where the rattle is coming from. If I am to guess, I suspect your heat shield to the exhaust pipe under the car.
As for your other question, which model of Honda and which engine does it have. Ask the seller which oil seal he is referring to. You have front main seal, rear main seal, camshaft seal, distributor seal. These are all oil seals, not to mention gaskets.
SPONSORED LINKS
Thursday, March 12th, 2009 AT 11:51 PM
