Hi I just replaced the starter, and sylnoid and when I turn the itkey it clicks once
Sunday, June 20th, 2010 AT 7:56 PM
MECHANIC
I need you to check something. First, have a helper turn the key to the start position while you check for voltage to the small wire to the starter. There should be 12+ volts. If there isn't, remove the starter relay and check if there is power to it.
