Vehicle will not start
JAG925
Electrical problem
1998 Ford Expedition V8 Four Wheel Drive Automatic
he battery and alternator were both replaced about 3 months ago. When I turn the key all dash lights, radio, etc. come on and as I keep turning the key I hear one click and then nothing happens. I removed the battery cables and cleaned the terminals. Also, checked all the wires that lead to the starter. Tapped on the starter with a hammer and still nothing. I drove the car about a half hour before with no problems. When I went to leave again it wouldnt start. Any idea what it could be?
Dec 27, 2008 at 4:43 AM
  • 110,248 POSTS
Hi:
What you need to do is check for power to the starter. Have a helper turn the key to the run position while you check for voltage to the smaller of the two wires at the starter. You should get 12 volts. Let me know what you find. Also, you may want to check the starter relay. Swap it with another relay with the same part number to see if that makes a difference. I believe you will find it under the hood in a power distribution center. The lid should be labled with what each component does.
Dec 30, 2008 at 8:12 AM
JAG925
Thanks for the info. I replaced the relay fuse, but that didn't work. So we went ahead and removed the starter and took it to the auto parts store for testing. Sure enough it was not spinning. So, $135 later and the car is working. Thanks for the help.
Dec 30, 2008 at 8:33 AM
ELGIN BOND
hey @Jag925, was your starter new? because i am having the same problem but i just replaced my starter yesterday and still get nothing? just wondering if i should take it off and take it to AutoZone to test it before i go and buy the relay switch.
Sep 16, 2020 at 2:49 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately you've attached your question to one that is years old.What we ask you to do is start a new question and be sure to include all your vehicle information.Here is the link to start a new question:
We will be looking for your new question.Hope this helps and thanks for using 2CarPros.
Sep 16, 2020 at 7:23 AM
