I recently took my Ford Explorer in to be checked due to a fuse that was continually blowing when I used the automatic door locks. The service shop told me that the fuse if blowing because of bad door lock actuators and they are pullijng a highier amperage than the fuse can take in oder for them to operate. I am able to use the locks one or two times after I replace the 30 AMP fuse each time before it blows. The mechanic said that all 5 actuators needed to be replaced. Is it possible that only one of them need be replaced and is there a way I can check to see if any one of them is bad. (ie. a fairly uncomplicated method to unhook each door lock from the electical circuit one at a time to see if this works.) I figured I would start with the back door lock first but wanted to get your advice. Thanks you for the website and your time!
Jan 1, 2008 at 7:00 AM
