1998 Ford Escort Reverse Lights Out
AGNES
1998 Ford Escort Wagon
Manual 1.8 124,000
Back up lights stopped working.
We....
Replaced the bulbs
Replaced the Fuse
Still wont come on.
Please assist.
P.s - This is a great service you provde
Feb 26, 2007 at 12:25 PM
LITTLEBIGBRONCO
  • 9 POSTS
there in a backup lamp switch on the transmission that could be the problem if both the reverse lights dont work
Feb 26, 2007 at 2:04 PM
BHUGG
  • 157 POSTS
Check under the hood for the power distribution box. This box has more fuses and the problem might be in there.
Does your flasher work? They are on the same circuit.
If the flashers work, then it might be the backup lamp switch that "littlebigbronco" mentioned. That is the only other device in the circuit.
If we help, let us know. If you dare, give us a vote. We are volunteers that like to help.
Feb 26, 2007 at 4:04 PM
AGNES
Can you please tell me where I will find this?
Mar 4, 2007 at 8:40 AM
TAURUSWHEEL
  • 718 POSTS
There may be a tab attached to the shifter linkage that pushes a switch to turn on the reverse lights, have you run over anything lately, a snow pile or anything??? I had an 87 Taurus 4cyl 5 spd, I ran over a chunk of ice and bent the little tab.. it will be under the car on the trans, follow the shifter arms.. something to check
Mar 4, 2007 at 2:05 PM
Suggested Repair
Check the under-hood power distribution box for additional fuses and confirm the hazard flashers work, since they share the circuit. If the flashers work, inspect the transmission backup lamp switch and the shifter-linkage tab under the car that actuates it, which can bend if something is struck.
Conversation Summary
The owner of a 1998 Ford Escort wagon says the reverse lights stopped working after the bulbs and fuse were replaced. Replies suggest checking additional fuses in the under-hood power distribution box, confirming the shared flasher circuit, and inspecting the transmission backup lamp switch or a bent shifter-linkage tab under the car.
