2001 Ford Escort No Start Fuel Pump
TAWARREN
We have a 2001 ford escort that was started without oil before we realized the oil pan was busted. It ran for a few seconds and shut off. Then after the oil pan was replaced it will not start. It turns over but will not start. The timing belt is fine and it is firing. We are wondering if it could be the fuel pump and how to test for sure to see if that is what it is without a lot of experimenting.
Nov 14, 2006 at 1:22 PM
BACKYARDMECHANIC
  • 337 POSTS
Hi Tawarren
You say that the car is firing so I'am assumming the car has spark. A quick way to check to see that the fuel pump is working is to listen to it. Have an assistant turn the key to the on postion ( Do not start the car) while you stay near the fuel tank and listen for the fuel pump running. If it is running you will hear it making a humming sound for a few seconds and then stop. This is normal If it does not make noise here are some things to check.
1. Check that the fuel pump fuse is good.
2. Check the inertia switch does not have to be reset. Check the owners manual for its location. It is either in the trunk or under the dash.
3. Check the fuel pump relay.
If all is good you may want to replace the fuel filter
4. Finally if you have a fuel pressure tester to check the fuel system and that the pump is suppling the proper pressure.
Good luck Backyardmechanic :)
Nov 15, 2006 at 1:32 AM
  • 55,746 POSTS
Nice, good work Backyardmechanic :D
Nov 27, 2006 at 3:02 AM
Suggested Repair
Confirm spark, then listen near the tank for a brief fuel-pump hum with the key on. If silent, check the fuel-pump fuse, inertia switch, and relay. If those are good, replace the fuel filter and verify fuel pressure with a gauge.
Conversation Summary
A 2001 Ford Escort was briefly started with a damaged oil pan and no oil. After the pan was replaced, it cranks and has spark and a good timing belt but will not start. The owner suspects the fuel pump. An expert advised listening for the pump to prime with the key on, then checking the fuse, inertia switch, and relay, replacing the fuel filter if needed, and testing fuel pressure.
