1998 Ford Escort Long Crank Fuel Pressure
FADO22
I have a 1998 ford escort lx 2.0 sohc with 57,212 miles with and auto trans .Everytime I start the car it seems to crank awhile and then starts. I went and changed the fuel filter and same thing so I checked the fuel pressure and it was zero when I turned the key on the pressure goes to 34psi and with the engine running it has 36psi at idle as soon as i shut the car off the pressure drops to zero. I checked a couple of books and i am getting different pressures for this car some say 36 to 40 psi and others says 55 to 85 psi. Now I am some what sure I asked a couple of friend mechs and they say the pressure should hold so everytime the car restarts it doesn't have to build pressure in the system for a easy restart. but nobody can give me the exact answer if the pump should hold pressure what is the pressure??
Any help please.
Aug 9, 2007 at 12:59 PM
  • 75,988 POSTS
[quote:028b0d8115="fado22"]I have a 1998 ford escort lx 2.0 sohc with 57,212 miles with and auto trans .Everytime I start the car it seems to crank awhile and then starts. I went and changed the fuel filter and same thing so I checked the fuel pressure and it was zero when I turned the key on the pressure goes to 34psi and with the engine running it has 36psi at idle as soon as i shut the car off the pressure drops to zero. I checked a couple of books and i am getting different pressures for this car some say 36 to 40 psi and others says 55 to 85 psi. Now I am some what sure I asked a couple of friend mechs and they say the pressure should hold so everytime the car restarts it doesn't have to build pressure in the system for a easy restart. but nobody can give me the exact answer if the pump should hold pressure what is the pressure??
Any help please.[/quote:028b0d8115]
The fuel pressure KOEO should read 35-55psi. losing the residual pressure like that could be cause by leakage on gas line/pump check valve/FPR/ and 1 or 2 injectors leaking-the system has to be tight.
Hope this helps
Aug 12, 2007 at 11:05 AM
Suggested Repair
Key-on fuel pressure of about 35-55 psi is acceptable. Residual pressure should hold after shutdown; inspect for leaks at the fuel lines, fuel pump check valve, fuel pressure regulator, and one or more injectors.
Conversation Summary
The owner of a 1998 Ford Escort LX 2.0 reports extended cranking before start. After replacing the fuel filter, pressure rises to about 34 psi with the key on and 36 psi at idle, then drops to zero as soon as the engine is shut off. The expert says key-on pressure should be 35-55 psi and that loss of residual pressure can come from a leaking fuel line, pump check valve, fuel pressure regulator, or one or two leaking injectors.
