how to install outer left tie rod for a 2003 ford escort zx2 with 47,000 miles
Nov 10, 2007 at 5:42 AM
Remove the front tire, cotter pin if present, and nut. Loosen the lock nut, separate the outer tie rod from the knuckle, and unscrew the end while counting the turns. Install the new end the same number of turns, seat it in the knuckle, tighten the nut, lock the lock nut, grease the joint, and reinstall the tire.
The owner asked how to install the outer left tie rod on a 2003 Ford Escort ZX2 with 47,000 miles. The expert described removing the tire and fastener, separating the old end, matching its turn count on the new end, then tightening, locking, greasing, and reinstalling the tire.
