1997 Ford Escort Oil Leak
SLAMDUNKTAY
hi i have an ford ecsort 1997 . i had recently had an oil change two week ago. then I began to notice a oil leak on the passenger side. Could this be the cause of the oil change and something being loose?
Jul 29, 2007 at 11:29 PM
  • 75,988 POSTS
could be the filter or the plug loose.better check it fast before you do some major damages.
https://images.2carpros.com/forum/automotive_pictures/12900_mechanic_1.jpg
Jul 30, 2007 at 12:59 AM
Suggested Repair
Check the oil filter and drain plug for looseness right away and correct any leak before low oil causes major engine damage.
Conversation Summary
The owner of a 1997 Ford Escort noticed a passenger-side oil leak about two weeks after an oil change and asked whether something was left loose. The expert said the oil filter or drain plug may be loose and should be checked quickly to avoid major damage.
