2002 Ford Escort Stalls and Burns Oil
WINGNUT413
I have a 2002 Escort, 68000 miles. After it warms up and runs for about 20 minutes it starts to knock & sputter then when I slow down or stop it acts like it wants to die and sometimes does. When I get it out of the car afterwards there is the smell of burning oil. Any suggestions as to what might be wrong? Thanks
Nov 16, 2006 at 12:32 PM
BRUCE HUNT
  • 3,754 POSTS
Start by checking the oil level and noting changes in the oil level and condition of the oil. Next, pull out a plug at a time and determine if they are oily in nature. I good clean plug should be dry and gray. A black, sooty, wet, oily plug is an indication that problems exist with that cylinder.
Your problems could range from simple to complex but start with the simple stuff and work up.
I take it the car keeps restarting and starts pretty well for you?
Nov 17, 2006 at 1:33 AM
LOSONE
  • 1,616 POSTS
Humm, Bruce is right about checking all the basics. If that doesn't work you may have a timng belt that is missing a tooth causing the engine timing to be off one tooth. The 02 Escort engine had a problem with the timing belt tensioner. Have a qualified mechanic check it out as it is not a home mechanics repair.
Good Luck
Nov 17, 2006 at 7:44 AM
Suggested Repair
Check the oil level and condition, then inspect the spark plugs one at a time for oil fouling or soot. If the basics check out, have a qualified mechanic inspect the timing belt and tensioner, a known issue on the 2002 Escort that can throw timing off by a tooth.
Conversation Summary
A 2002 Ford Escort with 68,000 miles knocks and sputters after about 20 minutes of running, sometimes stalls when slowing or stopping, and smells of burning oil afterward. Experts advised checking oil level and condition and inspecting plugs for oily or sooty deposits, then having a mechanic check the timing belt and tensioner if basics do not explain the problem.
