1992 Ford Escort Ignition Switch Fails
thanks, jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others
Why do you think it is in the ignition switch?
Is the car turning over?
What is failing in the ignition switch?
If we help, let us know.
Vote for us, it good for our ego.
Suggested Repair
Before replacing the ignition switch again, inspect the manual lever position sensor on the transaxle and the related wiring that runs into the instrument cluster. Confirm whether the starter actually cranks or the switch itself is failing.
Conversation Summary
The owner of a 1992 Ford Escort LX with 182,000 miles reports that the ignition switch fails about three times a year. After replacing the previously suggested neutral safety switch, the key sometimes does nothing on the first try and the engine cranks on the second. An expert said the remaining circuit components to check are the manual lever position sensor on the transaxle and the wiring into the cluster, and shared a diagram. Another expert asked for a clearer description of whether the car cranks and exactly what fails in the switch.
