1991 Ford Escort No Start Fuel Pump
UNGADIN
1991 Escort 1.9; Automatic;160000miles
Installed new fuel pump a couple of years ago.
Now it dies on me while driving, or pump does not come on at ignition. It will start on occasion. I took the outlet hose of the fuel filter off and I had someone look at the filter as I cranked to see if fuel came out. I replaced the filter last year. No fuel came out so I guess there is no power to the pump. Im thinking it might be the fuel pump relay. Im trying to look at a schematic that is in the Haynes book for my car. I can't make heads or tails of it. Am I on the right path? Where is a good schematic for the fuel system or where is the fuel relay? What should I do next?
Thanks
Ken
Aug 21, 2007 at 10:28 AM
  • 75,988 POSTS
[quote:be70bae826="ungadin"]1991 Escort 1.9; Automatic;160000miles
Thanks
Ken[/quote:be70bae826]
The fuel pump relay is in the forward of center console.
Also the inertia switch is in the right side of the cargo area above the wheelwell.
Aug 21, 2007 at 11:03 AM
  • 75,988 POSTS
[quote:46c37c8be2="ungadin"]1991 Escort 1.9; Automatic;160000miles
Thanks
Ken[/quote:46c37c8be2]
The fuel pump relay is in the forward area at center console. F/Pump relay location is in your email
Also try checking the inertia switch in the right side of cargo area above wheelwell.
Aug 21, 2007 at 11:23 AM
Suggested Repair
Check the fuel pump relay in the forward area of the center console and the inertia switch on the right side of the cargo area above the wheelwell.
Conversation Summary
The owner of a 1991 Ford Escort 1.9 reports intermittent no-start and stalling while driving. No fuel came from the filter outlet while cranking, so the owner suspects the fuel pump relay. The expert says the relay is forward of the center console and the inertia switch is on the right side of the cargo area above the wheelwell.
