1999 Ford Escort wont start
FIXUA
  • 1999 FORD ESCORT
Engine Mechanical problem
1999 Ford Escort 4 cyl Two Wheel Drive Automatic
turns over but wont start
Sunday, November 8th, 2009 AT 9:26 PM
Do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Monday, November 9th, 2009 AT 10:34 AM
