1999 Ford Escort car wont start when its hot
JEBUS1
  • 1999 FORD ESCORT
  • 4 CYL
  • FWD
  • 150,000 MILES
Ok just picked up this ford escort they told me what was wrong when I bought it. They would drive this car 2 hours to work daily didnt have any problems. Now when you shut the car off it wont start again untill it cools down. I say no problem I buy it drive it home well 4 hours late I try to start it and it wont start got no fuel and no spark. I changed the crank sensor on it and it started right up. Now it still wont start after its gets hot drove into town and back then waited 2 hours and tried to go to work. Wouldnt start. Car rolls over just wont start. As soon as I got home from work I turned the key and it fired right up.
Wednesday, August 5th, 2009 AT 11:11 PM
You're getting spark now after the CPS was replaced-are you getting fuel? If so check the fuel pressure if its within specifications.
Thursday, August 6th, 2009 AT 2:42 AM
JEBUS1
No spark no fuel. Just changed coil pack drove it for half an hour shut it off and wont start 5 mins later. The parts I can get only go up in price from now. Im thinking the PCM or the ECU
Friday, August 14th, 2009 AT 4:31 PM
Check and test the PCM power relay in the constant control relay module and also the fuel injector and fuel pump fuse.
Friday, August 14th, 2009 AT 4:38 PM
JEBUS1
All the fuses are fine how would I test power relay for the ccrm
Friday, August 14th, 2009 AT 5:27 PM
Swap the relay with a like one.
Friday, August 14th, 2009 AT 5:29 PM
