Engine Cooling problem
1999 Ford Escort Engine Size unknown Front Wheel Drive Automatic 940000 miles
I need to change my thermestat and can not find it.
Saturday, March 29th, 2008 AT 4:41 PM
MECHANIC
If u look on the drivers side of the engine. And follow the upper radiator hose to a plastic flange attatched to the motor there should be three 8 to 10mm bolts 2 on top and one underneath. The one underneath I used 1/4" drive socket wrench with a short extension to get off. It also helps to take off the air filter tube and move it back to the back of the engine bay. After u get the upper radiator hose off the thermostat will just be resting inside the housing.
