1999 Ford Escort temperature sensor
TMCPHAIL57
Engine Cooling problem
1999 Ford Escort 4 cyl Front Wheel Drive 199500 miles
My temperature gauge is flucuating between cold and the middle. I was told it is a teperature sensor problem. Can you show me or tell me where it is?
Sep 27, 2008 at 8:41 AM
BMRFIXIT
  • 19,053 POSTS
its in the thermostat housing
I would suggest checking coolant level
check thermostat
check sensor connector wires
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sep 28, 2008 at 12:26 PM
