1999 Ford Escort not firing
MARGARETCALIX
  • 1999 FORD ESCORT
Engine Mechanical problem
1999 Ford Escort 4 cyl Front Wheel Drive Automatic
i changed the coil pack but it's steel no fire to start the car
Wednesday, October 28th, 2009 AT 10:51 PM
But it's steel no fire, If you're talking about spark-check below
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, October 29th, 2009 AT 3:20 AM
