1999 Ford Escort lack of power
MCGUIRE425
  • 1999 FORD ESCORT
  • 4 CYL
  • FWD
  • 100,000 MILES
Hi, My wife has a 99 ford escort sohc, I just replaced the EGR and the DPFE and thel hoses to them and gave it a tune-up but the car still runs bad when you first take off, the engine light is now off, it did have a p0401 code then I replaced these parts. Is there something im missing. Thanks for any help
Saturday, June 19th, 2010 AT 8:03 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking, fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sunday, June 20th, 2010 AT 4:33 AM
