1999 Ford Escort help me please
FABOLOUS_DIVA33
  • 1999 FORD ESCORT
Engine Performance problem
1999 Ford Escort 4 cyl All Wheel Drive Automatic
i can start it but it will keep cutting off and I put gas in it what should I do
Sunday, October 11th, 2009 AT 6:50 PM
  • 31,937 POSTS
Run a scan for any unresolved fault codes, check the fuel pressure and flow, check that it has spark and injector pulse when it stops, I feel that this will be a fuel related problem,
Mark (mhpautos)
Sunday, October 11th, 2009 AT 6:53 PM
FABOLOUS_DIVA33
I can start it but when I get it started smoke comes is it my engine or do I need a new head gasket get back asap
Sunday, October 11th, 2009 AT 7:14 PM
  • 31,937 POSTS
What colour is the smoke? Black is excess fuel. Blue is oil white is a coolant problem.
Mark (mhpautos)
Sunday, October 11th, 2009 AT 7:29 PM
FABOLOUS_DIVA33
White what should I do
Sunday, October 11th, 2009 AT 7:32 PM
  • 31,937 POSTS
Hi there,
You will need to get a head check done, this will tell you if there is exhaust gasses in the cooling system, this is a quick simple test a most mechanics can do while you wait, if it is a positive test you will have a head or head gasket problem, if negative, there will be a problem around the inlet manifold with coolant entering the engine, If it is running rough and loosing a lot of coolant and getting hot I would be thinking a head problem.
Mark (mhpautos)
Sunday, October 11th, 2009 AT 7:39 PM
