HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Drivetrain
Transfer Case
SPONSORED LINKS
1996 Ford Escort
RONALDACREMAN
MEMBER
1996 FORD ESCORT
Transmission problem
1996 Ford Escort 4 cyl Front Wheel Drive Automatic
Transmission will not go in gear when cold.
Sunday, February 22nd, 2009 AT 4:03 PM
BILLYMAC
MECHANIC
Does shifter move into gear and trans won, t move? Or shifter stuck in park?
SPONSORED LINKS
Friday, February 27th, 2009 AT 9:35 AM
RONALDACREMAN
MEMBER
It will go into park it just won't engage until it warms up. The fluid level is fine and it doesn't slip.
Monday, March 2nd, 2009 AT 6:59 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1997 Ford Escort Help Meee
1997 Ford Escort 4 Cyl Two Wheel Drive Manual Hi, My Girlfriend Bout Her Car From A Guy And He Said That The Speedo Didnt Work But...
Asked by
ptotheimpin
1997
FORD ESCORT
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1972 Ford Escort Dying
Engine Performance Problem 1972 Ford Escort 4 Cyl Two Wheel Drive Manual Hi, Can You Help Me As The Engine Idles Great But When...
Asked by
rayray1971
1972
FORD ESCORT
1998 Ford Escort
1998 Ford Escort 4 Cyl Front Wheel Drive Automatic The Brake Lights Will Not Go Off Had To Take Fuse Out To Make Them Go Out Then It...
Asked by
csj6553
1998
FORD ESCORT
1997 Ford Escort
Engine Mechanical Problem 1997 Ford Escort 4 Cyl Front Wheel Drive Automatic I Turn The Key And The Car Dont Start. The Motors Turning...
Asked by
jdmboyz201
1997
FORD ESCORT
1999 Ford Escort Help Me Please
Engine Performance Problem 1999 Ford Escort 4 Cyl All Wheel Drive Automatic I Can Start It But It Will Keep Cutting Off And I Put Gas...
Asked by
fabolous_diva33
1999
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Transmission Service - Manual
Transmission Filter and Fluid Replacement
Online car repair manuals
