Engine Mechanical problem
1997 Ford Escort 4 cyl Front Wheel Drive Automatic
i turn the key and the car dont start. The motors turning but its not kickin over. Sounds like it needs to b timed again
Monday, December 1st, 2008 AT 8:10 PM
ZACKMAN
MECHANIC
Check to make sure you have the correct fuel pressure.
SPONSORED LINKS
Tuesday, December 2nd, 2008 AT 9:20 PM
RICK 08
MEMBER
Turn the key and the car dont start. The motors turning but its not kickin over. Sounds like it needs to b timed again
Your discription is un-clear to me, When you say the motor is turning do you mean the engin or the starter motor?
We can better help you if can better articulate.
You say timed again > have you done this recently?
