1998 Ford Escort Fuel Pump
CHICKADEE030481
  • 1998 FORD ESCORT
  • 4 CYL
  • FWD
  • 180,000 MILES
What are the signs that a fuel pump is going bad? My car has been hesitating sometimes when I step on the gas, and now there is this noise coming from the back right where my gas tank is. I think it may have been my fault, for running the car until the tank was almost empty, even on the really hot and humid days.
Tuesday, June 10th, 2008 AT 8:00 PM
BMRFIXIT
  • 19,053 POSTS
Running it low on gas may cause the pump to overheat or run hotter then normal
fuel pump sits in the tank and fuel act as a cooler for it
have the fuel system pressure tested
check and or replace fuel filter
Tuesday, June 10th, 2008 AT 8:27 PM
