2001 Ford Escort fuel pump wont run
2001 FORD ESCORT
JOSH BAKER
Engine Mechanical problem
2001 Ford Escort 4 cyl Two Wheel Drive Automatic
after weldig on exaust system car will not start fuel pump wont run but it has spark
Feb 9, 2010 at 9:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuel pump fuse, fuel pump relay and make sure the inertia fuel shut-off switch did not set.
Feb 9, 2010 at 3:51 PM
JOSH BAKER
checked fuel pump fuse inerta switch and relay have fuel pump runing but car still wont start. pulled a plug and has fire but fuel injection is not working? this all occured after welding on muffler
Feb 10, 2010 at 7:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuel lines, may have melted fuel line preventing fuel from getting to engine.
Feb 10, 2010 at 7:09 AM
