HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Drivetrain
Transfer Case
1998 Ford Escort coolant
ARTEMIS9585
MEMBER
1998 FORD ESCORT
1998 Ford Escort 4 cyl Front Wheel Drive Automatic
what color coolant do I put into this car?
Sunday, November 23rd, 2008 AT 4:55 PM
BMRFIXIT
MECHANIC
I believe green coolant for the 98 use 50 /50 mix
or u can universal 50/50
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Sunday, November 23rd, 2008 AT 5:48 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1998 Ford Escort
1998 Ford Escort 4 Cyl Front Wheel Drive Automatic The Brake Lights Will Not Go Off Had To Take Fuse Out To Make Them Go Out Then It...
Asked by
csj6553
1998
FORD ESCORT
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1997 Ford Escort Help Meee
1997 Ford Escort 4 Cyl Two Wheel Drive Manual Hi, My Girlfriend Bout Her Car From A Guy And He Said That The Speedo Didnt Work But...
Asked by
ptotheimpin
1997
FORD ESCORT
1972 Ford Escort Dying
Engine Performance Problem 1972 Ford Escort 4 Cyl Two Wheel Drive Manual Hi, Can You Help Me As The Engine Idles Great But When...
Asked by
rayray1971
1972
FORD ESCORT
1997 Ford Escort
Engine Mechanical Problem 1997 Ford Escort 4 Cyl Front Wheel Drive Automatic I Turn The Key And The Car Dont Start. The Motors Turning...
Asked by
jdmboyz201
1997
FORD ESCORT
1996 Ford Escort
Transmission Problem 1996 Ford Escort 4 Cyl Front Wheel Drive Automatic Transmission Will Not Go In Gear When Cold.
Asked by
ronaldacreman
1996
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Axle Bearing and Seal Replacement
Transmission Service 65RFE RAM 1500 2013-2022
Online car repair manuals
