1998 Ford Escort after overheating water was added to no av
BIGFOOTDAVE
  • 1998 FORD ESCORT
  • 4 CYL
  • FWD
  • 100,000 MILES
Engine still overheats real fast, I have removed the thermostat but do not know where the ball bearing goes on what position on the clock do I set it?
Thursday, May 15th, 2008 AT 5:08 PM
Take the thermostat out and check again if its still overheating without it.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat, Pressure test the Rad. Cap, Clogged radiator, Fan clutch, Radiator electrical fan, collaspe hoses, water pump.
Thursday, May 15th, 2008 AT 5:54 PM
