1998 Ford Escort overheating
13,400 MILES • 4 CYL • FWD • AUTOMATIC
CHRISDORAN562
i have a 1998 ford escort...about 7 mo. ago i blew a head gaskst...i got it fixed the tech did a good job...but i nocticed that it would not hold coolant for along period of time...the car drove fine....resently the car over heated i shut it off and coasted down the hill to avoid further damage...i check the raidiator for pressure it was fine as well as the cap then i found a leak from the waterpump so i replaced it...the lower raidiator hose has a slite leak because i did not put it on the water pump flush...but the car sounds and runs great...but if i drive or let it idle for more that 10-15 min the temp shoots up and it overheats i think it the thermostate what do you think
Oct 7, 2010 at 7:07 AM
  • 75,988 POSTS
Try the thermostat and go from there
Oct 7, 2010 at 10:57 AM
CHRISDORAN562
well i replaced the thermostat...and its not over heating but its running real hot and then it will go down to regular temp...and then it get hot again...im so lost
Oct 7, 2010 at 1:16 PM
  • 75,988 POSTS
Try bleeding it -could be airlock if it continues to get hot get it block and pressure tested
Oct 7, 2010 at 8:16 PM
