1997 Ford Escort Car won't start
CATPRICE
  • 1997 FORD ESCORT
1997 Ford Escort Two Wheel Drive Manual 99000 miles
My partner seems to think it is the fuel pump as the car will turn over but wont start and you cant hear the fuel in tank when you turn it over? Is this correct and how do you replace it?
Friday, April 3rd, 2009 AT 6:42 AM
BMRFIXIT
  • 19,053 POSTS
Removal fuel pump
1. Release fuel pressure.
Disconnect negative battery cable.
Depress 2 clips securing front of rear seat cushion, and remove seat cushion.
Disconnect wiring harness connectors from fuel pump assembly.
2. Remove fuel pump access cover.
Remove any dirt from around fuel pump flange area.
Disconnect fuel inlet and return lines from fuel pump.
Remove fuel pump lock retainer ring, and remove fuel pump assembly.
Installation
Clean fuel pump mounting flange, fuel tank mounting surface and seal ring groove. Install seal ring in fuel ring groove. Install fuel pump assembly. Install and tighten fuel pump lock retainer ring. To complete installation, reverse removal procedure. Fill fuel tank and check for leaks.
Sunday, April 5th, 2009 AT 8:06 AM
