1996 Ford Escort smokes when first started
1996 FORD ESCORT
1TOMJ
Engine Mechanical problem
1996 Ford Escort 4 cyl Front Wheel Drive 163000 miles
white smoke when first started then stops smoking aftet a couple minutes
Feb 24, 2009 at 4:46 AM
ZACKMAN
  • 4,202 POSTS
If this happens only first thing in the morning and 40 degrees or below, I would not worry about it. If it is at higher temperature, or after the engine is warmed up, then I would worry and have a compression test (better yet, leak down test) performed on the cylinders.
Feb 24, 2009 at 3:35 PM
